Duane_the_tub
- Joined
- May 30, 2015
- Messages
- 5,309
- Reaction score
- 13,475
You have now. It's gotta be a defective Faber. I was running it with EB .10s and did nothing unusual that would have caused this. So strange.
Wow! How long was it in use?You have now. It's gotta be a defective Faber. I was running it with EB .10s and did nothing unusual that would have caused this. So strange.
Faber bridges should be aluminum with brass and/or titanium saddles depending on the model.I think that while the purity of metals these days is WAY higher, the inherent nature of Zamak is not all that strong. So if there is the odd unit that gets slightly poorly formed (which is sort of a given really statistically speaking) then it will be not that better than any other vintage bridge.
And for all its supposed 'advantages', the modern execution of the Nashville bridge is, as can be seen from the above photos, almost more likely to sag than the ABR it replaced (for that express purpose).
You aren’t on your own. I had this on one of Van Morrison’s guitars. I think it was a mid 90s LP Standard. I remember it was a tomato splat sunburst with gold hardware. Underneath the gold plating the metal they use is junk. Just pressure of the case will do it over a long period.You have now. It's gotta be a defective Faber. I was running it with EB .10s and did nothing unusual that would have caused this. So strange.
Perhaps someone should invent a mini truss rod for those bridges.You have now. It's gotta be a defective Faber. I was running it with EB .10s and did nothing unusual that would have caused this. So strange.
