quick question...
on my Epi SG,
1) if i select neck pick up i can control the tone and volume with the appropriate pots.
2) If i select bridge pick up i can control tone and volume on this pick up with the appropriate pots.
3) if i put the 3 way selector switch in the middle position, it sounds more like just the neck pick up, and if i turn the neck pick up volume to 0, all volume goes off (to zero- even tho the bridge pick up volume is at 10)
tapping on both pick ups gently with switch in middle position, i get output sounds in speakers from both pick-ups so im guessing they are both working together...
So, does the bridge pot control the overall volume when the toggle selector is in middle position? or is mine wired incorrectly??
I did check a diagram from a website and mine is almost exact except the capacitors on the tone pots come from the center pins and then earthed on the back of the pots.
Please help!!
thank you
on my Epi SG,
Please help!!
thank you
