I recently picked up a used Les Paul Standard with some GFS and Blues Engine pickups. The pickups are ok but the wiring hardness has butchered to the point where it needs replaced. The guitar plays well and I like the feel of the neck so I plan to keep the guitar for awhile but want to make some upgrades that do not break the bank.
Option #1
Saw that Obsidian Wire has a PCB based harness that looks good for @ $99 that could take just about anybody pickups. The down side is that you need to make the volume and tone holes larger to accommodate the larger diameter pot shafts and you need to purchase new knobs.
Option #2
You can buy a set of Probuckers with quick connects and a stock wiring harness with coil splits for about the same price as Option #1. This is the exact setup in used the Epiphone Les Paul Custom Pro series.
Option #3
Scrinia Engineering offered an upgrade to the stock quick connect wiring harness with coil splits and adds a phase shift pot for @ $ 80 that could be used with the Probuckers.
https://reverb.com/item/12119565-epiphone-les-paul-wiring-harness-coil-split-phase-shift-new
Any advice would be welcome.
Thanks
Bill
Option #1
Option #2
Option #3
Thanks
Bill
