Epiphone Pickup screws different size than Gibson and others?
shooterkc
I have a guitar that I'm swapping the Epiphone Pickup back into the bridge. After I took out the SD pickup that was in the bridge I noticed that the pickup holes (the holes that the adjustment/mounting screws with springs screw into) are larger than the SD pickup I pulled out. It doesn't appear they were tapped or drilled out larger. Do Epiphone's use larger adjustment screws than Gibson/SD? If so does anyone have a couple or know where I can pick some up?
Thanks in advance!
Scubaman
Epi screws are Metric (M2.5 from memory) whereas Gibson uses Imperial (3/32" UNF)
Available from Stewmac and loads of other places
