Epi Les Paul overhaul?
MineGoes211
I'm looking to chang out the pickup (I may swithch to Gibson Dirty Fingers in bridge, and 490R in neck), and vol/tone pots on my Epiphone Les Paul Plus Top Pro FX (which has the push/pull coil spit volume pots). Is there a pre made pot set I can buy that will just pop in to replace the original? Any help would be great (please post links also)
Thanks!
SJM
Epi Elitist Freak
I've used the Martin6String coil split harness myself. Premium custom taper CTS pots, PIO caps with the series links for your coil split already soldered in for you. Easy to install.
Brian in NJ
Some sources say short shaft pots for Epi guitars, but I know some people have run into issues like not having enough threads exposed for the nut to grab. Long shaft pots will always work. For my upgrade I used long shaft pots and then used flat washers as spacers to set them at the desired height.
paruwi
Kraut-Rocker
that's why.....
MineGoes211
Update: I called the luthier I use at Sauve Guitars, and he has an old Dirty Fingers pup and can do all the pots and all, so in about a week I should have a new guitar!
Lutherie
Just make sure he got premium CTS pots and PIO caps, both Martin and Jonesy would hand pick those and make a 50s wireing hardness for you.
I am not saying he can't do it, just make sure you are hetting the real deal.
MineGoes211
I'm having the Dirty Fingers pup in the bridge and a Super Distortion in the neck... My Les Zilla!!!
Kamen_Kaiju
Not just that, Matt/Martin6SC tests every single pot to make sure it's overspec.
So when it warms up it doesn't drop below 500k (which many do)
99.9% of the folks that sell pots won't do that, which is why I only go to Matt for my parts.
MineGoes211
Yeah, I went over all the advise I got here with my tech, and he's well capable of taking care of me. I've been using Sauve since 1979.
hotzlaw
Hmmmm.
I've never noticed that the pots get warm. Why would they?
GitFiddle
:thumb:
When I'm not playing, I use my pots to cook some tasty soup. :laugh2:
MineGoes211
Got my Les Paul back, and I have one AMAZING sounding tone monster! I'll post pics tomorrow!!
Barcham
Elitist Club Member
Hmmmm.
Because they have an electrical current going through them. You never tough the pots when playing, actually unless you pull the cover off you'll never touch the pots at any time, so there's no way you would ever notice.
paruwi
Kraut-Rocker
Hmmmm.
Now I know where the smoke is from while playing...:naughty:
:wave:
hotzlaw
Ok, thanks.
I always thought that an amplifier was required because the voltage and current generated by the pickup was so miniscule.
