Here's a zebra T-Top set I had. These came out of a 1979 SG. You might notice there is no solder on the baseplates where covers would attach. They are factory uncovered zebra T-Tops. Not common, but the end of the 70's were a strange and bizarre time.
You'll also notice they are ceramic magnet pickups, with much larger magnets, pole screws, spacers, and slugs than previous T-Tops. ...and, accordingly, sounds nothing at all like a T-Top you might have in your mind. More like a jangly Super Distortion. Gibson did some weird stuff in the late 70's and early 80's.
They weren't all ceramics, just because of the bobbin color and/or factory uncovered design. I also had two other zebras that were both A5s from the same year. ....probably still have them?Hmmm, that kinda threw cold water on my plan!
Ceramic, NG for me!
You do know the magnet is not welded to the rest of the pickup??Hmmm, that kinda threw cold water on my plan!
Ceramic, NG for me!
The slugs and plastic spacers would have to be replaced, at least. That magnet is twice as thick as an AlNiCo bar (unless you use a Filtertron AlNiCo). The slugs would protrude out the top of the coil, otherwise.You do know the magnet is not welded to the rest of the pickup??
4 baseplate screws undone and the new one slides right in. And late 70's mags seem fairly close/identical in formulation with modern types.
Man, I love this place..The slugs and plastic spacers would have to be replaced, at least. That magnet is twice as thick as an AlNiCo bar (unless you use a Filtertron AlNiCo). The slugs would protrude out the top of the coil, otherwise.
They just used a regular keeper bar, which kinda flops around loose under the screw coil, for some reason. I'd have stacked two. I suppose they didn't do that because they were no longer precisely machined, at that point. Because of the wonky wobbly shape of those sloppy 70's stampped steel keepers, two would be TOO thick and not fit, unlike the original machined ones of the 50's and early 60's.
