How do you figure. Resistance is direct relation to the length of wire around a bobbin. More wire used = higher resistance. Looser = larger coil wrap (i doubt very much larger unless it is wound haphazardly.. don't know though since I have never wound a pickup)A looser coil will require more turns to reach the same resistance as a tightly wound coil.
I think a buddy of mine on The Gretsch Pages put it very well when he posted this:
Originally Posted by mikelevitt
When you play, the strings vibrate, and the pickup senses the movement of the strings through the magnetic field. With a potted pickup - this is all you hear. We'll call this "pickup tone."
With a non-potted pickup, the pickup coil itself moves slightly in relation to the pickup magnets when you play - because the vibration of the guitar body is shaking the coil and making it move in relation to the magnets. You can hear this by tapping on the body of a solid guitar. It's called microphonics because the process is exactly like a dynamic microphone where a coil of wire moves around a magnet. We'll call this "body tone."
Technically speaking, a smaller bobbin will require more wraps to get the same length of wire around it that a larger bobbin has.
I disagree. The sound you hear when you hit the body is that of the strings vibrating. A hit will cause the body to vibrate in turn causing the strings to vibrate.. can also be direct impact force that the strings see which cause them to vibrate lightly (I mean just the movement of the body quickly in relation to the strings.. momemtum and all. The strings want to stay where they are in relation to the world while the body moves under them.. then the tension of the strings cause them to move over where they were in relation to the guitar.. vibration.. ).
You can mute the string to stop the sound... you can also cause the same sound by tapping the headstock.. so I highly doubt it is the coil moving in relation to the poles.
Now tapping the pickups directly.. may be from the coil/pole relation that you speak of.
I had one MLPF winder tell me that hand winding a tighter wrap on the wire will in give you a brighter sounding pu (vs dull lifeless)and another winder not on this forum told me that machine wound pu's will yeild a brighter tone as well. Not sure how much of your capacitance theory will apply to those statements, but I take them to be true.![]()
you know i have done this for a long time so things I said 10 years ago dont always apply to what I do now. On my humbuckers I generally pot them for 30 seconds to keep the cover from squeeling but it leaves the coils with only the few outsidelayers waxed- the rest of the coil is un waxed. what happens alot of vintage pickups is the guitar gets dropped or knocked and it makes the unpotted coil shift- become much looser and becomes micrphonic to an excessive level all of a sudden.
this is something hadnt thought of 10 or 15 years ago, if you dont pot at all your pickup coil can shift and become too microphonic.
Now every design I make has specific perameters - everyone is different.
I will make unpotted buckers if you ask specifically for them but basically everyhting I make has a specific level of microphonics- I can also pot all the microphonics out but only do that on request.
there is no pat answer to this IMO
I have several humbucker sets; all unpotted, or should I say unpotted coils in the case of my WBs, from two different boutique winders.
I love how they sound.
BUt....
I was trying out a Heritage LP lookalike ( budget model w/ slightly smaller and thinner body ) which sports a set of medium power Lindy Fralin humbuckers and a lot of the magic is not present compared to the other sets.
I believe the Fralins are potted. The Fralins sound predictable and somehow darkish bland and I reckon it's due to the potting. No overtones squeaking under the fundamental, no swaggering tone, no sweet-yet-sad slight microphonic behaviour...
Could the wax the culprit? the pickups do sound good but compared to the others they just don't have much life to them. BTW the guitar still has the stock pots and switches....
