overdriver
- Joined
- Sep 7, 2007
- Messages
- 6,134
- Reaction score
- 29
GuitarNuts.com - Potting Pickups There you have it!
I didn't like the sound of my pickups when I used a lot of tension to avoid wax potting. When using a lot of tension, you're defeating the purpose of scatterwinding. The increased tightness of the coils decreases the distributed capacitance and to me dulls the sound. ...the pickup is not as dynamic and some high end is lost.
Probably teaching my granny to suck eggs, but tighter coils would mean an increase in capacitance, but the effect of this giving a duller sound is exactly as you state. C = (E0*Er*A)/d where d is the gap between parallel plates, I seem to remember for parallel wires the capacitance expression is a little more complicated, but definitely goes up as the gaps get tighter. I've got a full derivation of it somewhere...
Liam
i wanted to post something like this also, i read all about the OTP pick up thread last night, took almost all night to get through it too lol, and i like the idea of those pick ups, but i have modern amps...and i like to play the hard rock with some gain. I tend to love 57's but i like the OTP tone/ideals....so any guidance in the to wax or not to wax would be awesome....by the way Liam it was great to read your input on that thread, i really enjoyed it. I learned a great deal on that thread thank you sir!
You can definitely lose some of the magic along with losing the microphonics. If I have to wax a pickup I start out by doing so very lightly (3 minutes in the wax pot), as you can often kill the squeal and leave the pickup quite breathy sounding.
However, it's not a foregone conclusion - some well-waxed pickups can sound great. (e.g. 57 Classics)
Why not just play them without the covers? That should work.
Liam
That is why I said what I said in the previous post....tension has more effect on tone than does wax potting.
I had one MLPF winder tell me that hand winding a tighter wrap on the wire will in give you a brighter sounding pu (vs dull lifeless)]
and another winder not on this forum told me that machine wound pu's will yeild a brighter tone as well. Not sure how much of your capacitance theory will apply to those statements, but I take them to be true.[/COLOR][/B]
There are always exceptions to the rule but I believe that it isn't because of the tension that it would remain bright, it could be the parts that are supporting the higher frequencies even with a tight coil. Also, the pickup maker may not be using as much tension as he thinks when he is winding, therefore the pickup will remain on the bright side. The only way to be sure is to use a tensioner and test the different tensions. I have done this and a very tight coil will reduce the dynamics of the pickup. You also have to consider that you're stretching the wire as well which will make it darker (lose high end) and will increase the DCR.
I use both methods and I can tell you that you can make a bright-sounding pickup hand guiding the wire or machine winding, and you can make a darker sounding pickup by hand guiding the wire or with a machine. It doesn't matter, it's all about the technique and how you manipulate the different componants and your methods (tension, pitch, scatter/pattern, etc...).
I had one MLPF winder tell me that hand winding a tighter wrap on the wire will in give you a brighter sounding pu (vs dull lifeless)and another winder not on this forum told me that machine wound pu's will yeild a brighter tone as well.
I don't have any experience in actually winding pickups myself,(unwinding them) and do not claim to be an expert on winding them. I am largely going by what other experienced winders have told me and I make a mental note of what they say, just like I am with the information you have posted.
Different types of wire. and the amount of winds (more winds/ohms darker or loss of high end) and magnets will also have an impact on how bright a pickup sounds, I know this from tinkering over the years. Winding is not an exact science and methods will vary just like wiring guitars, but I can't see how a loose wrapped wind will produce a brighter sounding pickup by having larger air pockets between the wire?
Based on materials, methods, and individual techniques, each maker will have different results.
