freefrog
- Joined
- May 21, 2011
- Messages
- 1,642
- Reaction score
- 1,030
I share below a few data that I had in my mind while replying to a recent topic.
I just needed to edit the related screenshots (expurgated below of some essential data for questions of intellectual property; thx for your understanding about that).
GEAR USED:
-Gibson Flying V with low output P.A.F. clones, uncovered. Resistance: 7.8k & 7.2k. Inductance: 4.2H & 3.6H. UOA5 mags, 500k volume pot, 250k no load tone.
-Fuzz Face with low hfe NOS (silicon) transistors.
-Various cables:
*two 10ft Sommer “Black Zilk”, ultra low capacitance (each measuring a stray capacitance of 185pF, jack plugs included);
*one single 10ft coily cord, measuring a stray cap of 1nF (=1000pF. It’s the average value of a straight 20ft cable and it’s logical, since a 10ft coily cable includes roughly 6m of cable coiled on itself).
*one single 60ft straight cable, measuring the expected parasitic capacitance: a whooping 3.2nF (=3200pF). It’s almost ten times the overall cap of the two Sommer cables altogether.
TESTING RIG:
-an ultra low impedance air coil has been used to excite the neck PU.
-this air coil has sent a swept mono signal to the pickup then through the Fuzz Face (enabled), itself located between two of the cables mentioned above. Final host: a 1M input.
-the frequency response and THD measured in each case has been captured thx to the dedicated testing hardware and software devices (not to be revealed here).
WHAT THE SCREENSHOTS WILL SHOW:
-upper horizontal lines: frequency response.
-lower horizontal lines: THD.
-red lines = the Fuzz Face before an average BUFFER… Blue line = the same pedal plugged directly to a 1M input, without buffer.
The buffer increases the distortion in the low frequencies and makes this distortion bassier, whatever is the measured frequency response. Conversely, any reduced THD in the bass and low mid frequencies reveals in which proportions the FF is thin sounding (and edgy/ harsh, as if a series cap was in the circuit)...
The cables change this THD as well as the frequency response as shown below…
GEAR USED:
-Various cables:
TESTING RIG:
