DaveR
- Joined
- Sep 14, 2013
- Messages
- 596
- Reaction score
- 999
Thought this could be helpful info for somebody like me who loves making their own tools on the cheap. I’m refretting a junk acoustic because I want some practice and wanted to buy the StewMac jaws 3 but couldn’t justify the expense. I already have the Philadelphia Luthier caul and brass inserts for my DIY arbor press. So I bought a 12” bar clamp for a few bucks on Amazon, chopped off the swivel foot and used a scrap block of aluminum with some carefully drilled holes to hold the whole mess together.
The large hole for the acme thread of the clamp is a real tight fit and the set screw clamps down on the ball end. The other side is loose enough for the caul to swivel as I tighten the clamp and the set screw just keeps the caul from falling out.
I wound up doing the whole guitar with this clamp because my arbor press is in the garage and it’s cold out there. Took a little bit longer this way, but I was toasty warm in the dining room. The clamp worked through the sound hole for 17-20. 14-16 I clamped around the back of the guitar with a cork faced clamping block. 1-11 worked with my normal cork lined neck holding jigs that I use with my press. I had to break out a hammer for 12 & 13 because I just couldn’t get a grip on anything with the clamp and that area won’t fit in my press either. I’m not very skilled with the hammer, but it’s amazing how water and a soldering iron pulled out the dents I left in the FB like a real idiot...
