LtDave32
Desert Star Guitars
- Joined
- Mar 19, 2010
- Messages
- 45,103
- Reaction score
- 149,408
*EDIT* This thread started out as an inquiry, but I decided to change it to a "how-to" tutorial, as there is a lot of interest on how to get through this.
I went and ordered a blank of Nylon 6/6 material, 3/16 thick, one inch tall and ten inches long. So the commentary is a little out of sequence. But the photo procedures are right.
This stuff is a bitch, boys..
How in the hell do some of you cut string slots in a blank of Nylon 6-6?
It's already warped my .010 slotting file. So I went to the .013 which is stiffer, but not by much.
There's no filing powder after cutting. This is the toughest material I've ever run across. Not "hardest", but "toughest".
I've heard they case roller bearings in this stuff.
So far, I think I've made a "dent", but not to sure if I've made a "cut", if you get what I mean..
Christ, they ought to make dog chew-toys out of this stuff..
Anyway, I bought a bar of 3/16" thick Nylon 6/6. pretty good deal at $8.00 and change, enough to easily do ten nuts.
Here we do the typical thing of lining up the string slots from a standard nut and marking them.
*Note: the marking goes a whole lot easier if you take a piece of 220 paper and scuff the Nylon 6/6.
Otherwise, pencil doesn't show up too well, and it wipes off too easy. Sanding surfaces to be marked was the perfect cure.
Now we're going to score those pencil marks with a razor knife:
