Custombucker Measurement - Neck vs. Bridge
cooljuk
Transducer Producer
I just received a new '22 R8. Slight damage in shipping so I am speaking to seller about it.
But the custombuckers read 7.0k exact in both neck and bridge. It wasnt listed as low wind and is not a Wildwood spec or S Bucker (CME). Sounds quite good but I thought I was getting the "normal" winds..
I'm not sure there is a "normal Custombucker" as they are all over the place in measurements and sound.
I'm still convinced that when a spool of wire runs out or breaks mid coil at Gibson, they just throw that coil in the "Custombucker / Signature Series" bin for production.
alane011
7.0k in the bridge seems lower than Ive seen folks posted even for the low wind CBs - its bright for sure but not thin so I am not sure what else is going on. I do think the neck at 7.0k is better than other CBs Ive tried.
1allspub
Bridge = higher is the “usual” nowadays... but by no means is it a hard and fast rule.
Why not try it both ways and stick with the way that sounds best?
vanguard
Paul Kossoff's burst was like 7.7k in the bridge and and 8.6k in the neck. Sounded pretty good!
The stock custombuckers in my '19 R9 both measured 8k on the dot. Terribly balanced. The neck was a muddy mess. Bridge sounded pretty good, but had that typical Gibson-made zing I don't like.
alane011
I wanted to try the narrow tall so I just sold my '21 R8 (59 wire) to a friend that had 8.22 bridge and 7.54 neck. My new '22 with the 7.0k neck and bridge has an insert that says it has "new historic spec wiring harness" whatever that means. I definitely like the 7.0k's better although I have to dial back a bit of bridge tone. Very clear and compelling. The 7.0 neck is pretty great. The 7.54 neck in my '21 was very muddy no matter what I did with pickup/pole height. I have a set of Doyle Coils that I was going to install but I think I will wait.
Guitar Rod
My R9 has the lower wind in the neck. 8.05k neck, 8.08k bridge. :D
