Cupcake? Heresy? Pony? 4 stacks of plexi?
Pop1655
Platinum Supporting Member
Dav: I need to do that with my little Marshall but I fear I’m not gonna be impressed. Have you ever tried headphone out instead of usb?
DavGrape
"Call me Gaspár."
SuperChamp has a line out that I can run straight into computer, but that's mono out.
The line in on PC is stereo, you end up only one channel.
I had to go thru small mixer to get a stereo signal for PC
It sounds good, tho.
A headphone out is stereo, that could easy go into line in on PC, might be too weak, tho.
lost the fry cook
It's just hard to put into words! Haha!
If you saw it being done it would make perfect sense.
sonar1
Original Track
Awesome tone & chops!
:headbanger:
Meanwhile, I futzed my way through “Buckaroo” for my daughter and a friend.
I’m a long ways from Bakersfield, and not gaining on it much either.
But I didn’t do bad on Malagueña, so lunch was Mexican food ( on me of course).
I’m a long way from Carlos Montoya too.
DavGrape
"Call me Gaspár."
Getting Windows and your recording software to know what you're doing can be a challenge.
It knows you're using the USB port, but doesn't know what to do with it.
Same with the line in; it might be disabled or muted.
And ASIO audio drivers are needed, or you get lag times between input and results.
sonar1
So THAT’s how you play it!
Stellar.
I just futz around in D at the first position. Never knew how that managed the upward key changes, being anchored.
