lpfaded
- Joined
- Apr 23, 2009
- Messages
- 78
- Reaction score
- 5
To the OP thr "RO" stamped in your control cavity is the first clue and is more informative than the Pots/caps. Second, I would string one ground wire from the Rythm Tone Pot body across to the Treble Tone Pot body (see Aceluek's wiring). Right now your Bridge is grounded to the Rythm PU Circuit but not to the Treble Circuit ground. Any continuity between them would have be at the toggle switch area or be the uninsulated shields touching in the wire routing cavity.
Thanks i was thinking the same thing looking at this wireing setup....with that wire missing is does not complete the circut....Would you just solder the wire on top from pot to pot?....Also what gage wire would be best to use?....Thanks
