krauthammer
- Joined
- Dec 28, 2014
- Messages
- 218
- Reaction score
- 137
Hi guys,
First, let's get the set up out of the way:
Marshall JCM 2205c
MXR Dyna Comp first pedal running through the effects loop
Les Paul Studio
Me = totally amateur guitarist just trying to get better
So.... I am noodling around, trying to get a good tone. Figured I should try to run my pedals through the effects loop on my high gain amp. I've got the compressor, then a chorus, then a phase 90, then a delay, into the loop. Nothing is bowling me over, And then it happens:
I turn off every pedal, except the compressor. The amp is on the crunch side, orange channel. And there it is...
Pinch harmonics
Sustain
Creamy crunch
Hubba Wha????
I had no idea. When I turn the effects loop off, the amp doesn't sound as dreamy. Turn it back on again, there it is.
So, my question is....
Should I be running my compressor at the front of the amp, before the pre-amp stage, so that I can get that positive effect across all channels?
Should I not mess with success, and leave it where it is? Doing so would be a little trickier while playing with the band.
Is it giving me this type of effect because it's after the pre-amp stage, or will it work before the pre-amp?
Are you guys finding similar results? Where do you use it, if you use it at all?
Very interested in what you guys think, and what you guys have discovered. I apologize if this is old hat to seasoned players, but this has been quite a revelation to me.
Respectfully,
Your Hammer
Marshall JCM 2205c
Les Paul Studio
Pinch harmonics
Sustain
Creamy crunch
Hubba Wha????
Respectfully,
Your Hammer
