Grey_Goose
- Joined
- Oct 16, 2022
- Messages
- 12
- Reaction score
- 9
Greetings All,
In the aftermath of a deal falling through on a MIK Epiphone, I went a somewhat different route and purchased another Chapman, this one being an ML-2 Modern produced in Indo in 2017 (if I'm reading the SN correctly). For those unfamiliar with the ML-2, this is Chapman's foray into the Les Paul-style solid body. This particular instrument is pre-owned, purchased from a local GC. I have a few questions that I'm hoping some of you might be able to assist with.
Chris
- The pickups are not rock solid in the body, and securing them in place by tightening the mounting screws moves them quite a distance from the strings; even then, there's some slight wobble if I apply pressure, which is not what I have seen in my 2022 ML-1 or any of my other guitars. Additionally, the neck and bridge pups are at different distances from the strings, noticeably, and (again) comparing the distance to that of other guitars shows a pretty large difference. Do I need to insert a piece behind the pickups to move them higher in the body (e.g. towards the strings), or do I replace the mounting screws with something more along the lines of a post-type screw with a sleeve that gives me the necessary room for adjustment, or is there a different solution that I should consider?
- In the middle position of the three-way switch, I'm only getting sound out of my amp when both volume knobs (for the neck and bridge) are past the 50% point, more or less; is that normal?
Chris
