OK so Slash Tone?Both are electrically identical.
You have a resistor in series with a capacitor.
The important thing is that the tone control is landed on the volume wiper.
I think so too, but one dude told me that with different soldering there are differences in the interaction of the volume and tone knobs.Both are electrically identical.
Well, that's good to know! Thanks for doing the experiment.I tried both options right now. And I didn't hear the difference...
Maybe you simply misunderstood the 'one dude'.I think so too, but one dude told me that with different soldering there are differences in the interaction of the volume and tone knobs.
But the only difference between "Modern" and "50s" is the connection of the tone circuit to the signal chain (pickup or output side of the volume pot)Scarcely any misunderstanding.
Yep, we knew about Modern and 50s, and that on volume was 'the difference in one soldering joint'.
The dispute was about the tone pot.
What a coincidence!But the only difference between "Modern" and "50s" is the connection of the tone circuit to the signal chain (pickup or output side of the volume pot)
This:
---/\/\/\/\-----||-------v
Is electrically identical to this:
-----||-----/\/\/\/\------v
The tone cap can go between the pots, it can go to either the end terminal of the pot, the wiper terminal, or it can go between the pot terminal and the pot case ground.
It is a resistor in series with a capacitor shorting the high frequencies to ground.
You are using the same portion of the tone pot trace, so there is no difference in taper.
