db3266
- Joined
- Oct 18, 2010
- Messages
- 3,081
- Reaction score
- 2,004
I'm trying to decide whether or not to make some more changes to the wiring of my Telecaster harness. I think the bridge pickup is bright, too bright for what I play (I always think bridge pickups are too bright on any guitar). I have a 0.022 cap installed.
I have three options.
1. Install a larger cap, maybe a 0.033
2. add a resistor as per the Bill Lawrence schematic, which will tame the highs off the bridge.
3. add more capacitance into the circuit when the bridge pickup is engaged, ie, I could have a 0.022 in the normal position which will be used for neck and middle position, then add another cap (wired to the switch) with a value of my choosing, so that when the bridge is engaged, both caps are used.
I dont know what the trade off is between adding a resistor or adding an extra cap? I read that capacitors change the frequency range of the entire pickup, I'm really not sure what that means?
