Can this out-of-phase mod be done?
SpinWheelz
Here's the idea:
1 humbucker at the neck
1 single coil at the bridge
1 volume control
1 tone control
1 3-way switch
Can the humbucker be modded to be out of phase, using a push-pull pot? If not a push-pull pot, could a 4-way switch assign one position put the pickups out of phase?
If so, got any wiring help?
Cheers.
BCRGreg
It would be easier to flip the polarity of the single coil.
5F6-A
asingle coil and a full humbucker ( if untweaked ) would not get a nice OOP sound together. Too disimilar to sound good IMHO.
Liam
You should try it first before condemning. I had a tele that sounded great with SC and humbucker out of phase. The SC was a standard jap tele neck pickup, the humbucker was a Gibson 57 classic (so the other way round to you). SC phase was flipped on a push/pull volume knob, there are plenty of wiring diagrams for this. Another one I should never have sold...
SpinWheelz
So, no to reverse phasing the humbucker but yes to doing it to the single coil? It's likely that I suck at googling, but if someone could point me towards a wiring diagram, that would be quite helpful.
Thanks!
hillbilly
Here's the idea:
1 volume control
1 tone control
1 3-way switch
Cheers.
That's an easy one...yes...4-conductor wiring on your Neck humbucker on a push/pull for out of phase...
Or, flip the magnet in the humbucker for 'permanent' Out-of-Phase-ness...
Or, some companies pickups are wired out of phase with another...simply swap the 'hot' & 'ground' wires on one of the pickups...
Both my Tele's are wired for out-of-phase operation with humbuckers in the neck position--one with the magnet flipped, and the other (a FilterTron) with the wires switched.
Jason
That could very possibly sound terrible. I've got a Schecter with two completely different humbuckers and even those sound like absolute ASS out of phase. Like very clunky and tinny.
hillbilly
Only way to know for sure is to try it... :naughty:
Liam
Here's the roadmap:
Guitar Wiring Site
Phase reversal through a DPDT switch is near the bottom of the first page.
Doesn't matter which pickup you put out of phase, it sounds the same, just easier to do the single coil.
I don't think you'll get what you want from a 4 position switch, you can make them do series/parallel easy enough, but I don't think you'll get one to swap the phase.
Liam
