Can someone do a quick Explorer measurement? Please!
warmachine
Trying to find out the distance between the pickup adjustment screw of the Neck pickup and the adjustment screw of the Bridge pickup.
My Ibanez Destroyer DT520 for example measures 4 1/32" and I'm curious to whether the Gibson Explorers pickups are mounted similarly.
efstop
That's a big gap. My 2018 Explorer has 4" between the adjustment screws.
Damn near gave myself a hernia lifting that case and putting it back :D
warmachine
Actually I realize now I typed a 5 when I was aiming for 4!
4 1/32" is what I meant
Thanks for the reply! With this info I feel more confident in scoping out replacement pickups for the Destroyer by listening to Gibson Explorers on youtube. Not the same guitar for sure but definitely in the same vein.
efstop
I looked up a template for an Explorer and it specifies 100.6 mm, or 3.97-ish inches, so still not a huge difference. The pick up routs will be the same size, anyway. Humbuckers are pretty much standardized as far as length and width. Mounting legs may vary, but a short legged pickup should fit into any body and ring. Might have to use shorter screws/springs on them.
