Building a sound proof room.
Neffco
I’ve got a little space, 12x16 , that I want to build a sound proof room with a separate vocal booth/ cab iso booth, in one corner. That would give me basically three rooms including me “control room”/office. It would also still leave me room to put the drums outside, in their own, more open space, less dead room. Here’s a fancy napkin drawing. Total space is around 16x40. Opinions please. Keep in mind the control room is already a finished office/ studio.
Neffco
Here’s the control room for a size reference. I figured the sound proof room will be close in size minus the wall thickness.
  • Like
Reactions: Who
Neffco
I currently have the whole band in the control room. I believe I have a decent amount of room.
  • Like
Reactions: ehb
Lhdr
Soundproof would be lead or brick, brick would be easier. Be pretty easy to screw 6 sheets of 1/2“ drywall on top of each other but don‘t know if that would knock the low end Out. I know nothing about studios BTW.
CB91710
YT Channel DIY Renovations has some good advice on sound isolation for home theaters.
The thing is controlling air movement as well as sound movement.
Sound transmits through solid objects, but air movement through a surface transmits more.
Air gaps between layers of drywall... with the gaps sealed so they do not pass air between the layers, is your best isolation.
For sound proofing, filling the gap with open cell foam is helpful, but the main thing is preventing air from passing between the spaces, and reducing the flexibility of the surfaces that allows the walls to act as soundboards.
Who
I'm back. Back in the New York groove.
Are you soundproofing it from the outside (eliminate outside noises from entering the room) or are you trying to keep the sound from leaving the room?
I'm no scientist, but you are going to need mass and decoupling.
Please don't listen to anyone who thinks insulation has anything to do with noise reduction.
Also, paging @Freddy G . He knows a thing or two about sound.
I have designed and built several studios and I can tell you one thing. If you want isolation or "soundproofing" between rooms you have to do it right. You must dot all your "I"s and cross all your "T"s because if you don't you're just wasting time and money. So I just want that to be clear. But if you don't need soundproofing then just get the rooms to sound good, which is really the more important thing anyway. You can get very good results in acoustically treated, good sounding rooms that are not soundproofed.
Who
And, this will be expensive. Focus your money on soundPROOFing, and not sound absorption (if that makes sense).
A lot of "sound" advice is about reducing sound reflection (sound absorption). That's not the same as soundproofing.
Sound absorption is for the interior space of the room that has the sound.
Sound proofing is about the barrier of sound from one room to the next. They are similar, but not the same.
Example:
This is only speculation on my part. The panels and foam shown below probably help with the acoustic IN the room, but do very little to keep the sound from LEAVING the room.
I base my speculation on this.... If you were to wrap your body and head with the foam rubber triangles above, and have someone yell at you from across the room, you'd hear them very clearly.
But, If you put your entire body and head (briefly, of course) in a box of dirt and sand (mass and decoupling), then had the person yell at you.... you'd not hear a thing.
Again, I'm no expert. I did look into this once when setting up a basement theater/playing room. I decided it was too expensive. Done well, it also really encroaches on the size of the room.
Who
More info:
Norton
This is my day job. There is only one way to deal with sound isolation. And that’s as a system. Your space will only be as good as your weakest link.
First I’d strongly suggest that you create the largest most comfortable, most acoustically ideal control room. It’s where you’ll spend most of your time. If your control room sucks your mixes and your time TRYING to mix will suck.
As far as the isolation build out goes. The two best resources are:
1) the green glue website. The documents section is gold.
2) John sayers web forum.
If you want specific help pm me. I’d be happy to help you out via text etc.
Good luck!!!
Freddy G
It depends on how far down the rabbit hole you want to go. My advice would be that for a home/hobbiest studio it's far more important to have your rooms sound good than it is to have total isolation...ie. soundproofing. I only say this because to do soundproofing right it will cost a LOT of money, and space....you'll end up losing a lot of space because you basically have to build a room within a room which floats on rubber, and none of the walls or ceiling can touch the existing structure. Doing that for 3 rooms in total (each room would have to be built that way) it's going to be expensive and claustrophobic.
I might suggest that instead of 3 rooms just do 2 and an ISO booth. Make the live room the one that's soundproofed (room within a room). That way you keep the bleed from leaking out of that room to the rest of the building and also the control room.
You don't really need to soundproof the control room to prevent noise from leaking out. The control room is not when the loud stuff is.....you're just listening on monitors. The live room....where you have drums and amps....THAT'S what you need to soundproof if anything. But soundproofing does nothing for the actual sound of the room....the response. For the control room, treating it for response is far more important. Without having a control room you can trust, you will ALWAYS struggle with mixing and it will be supremely frustrating. And it's a lot easier to effectively treat a room for sound response. Spend the time to figure out where the problem freqs are in the control room....guaranteed you will need to manage bass response. After that broadband panels to tame reflections are a cinch.
redking
I've been struggling with this decision myself and have been paralyzed by indecision, so for now I'm working in my unfinished basement. Was thinking of doing 1 fairly big "room within a room" with the option of building a second one right beside it at a later time that can double as an overbuilt tv room. Then at that point, use one as a control room.
Another part of me just wants to rent out some unused space in a light industrial building and do it there, and then not worry so much about the soundproofing because I would be going there at night.
The biggest reason I have stalled out on this project is the heating and cooling - I can't wrap my head around isolating a room in a brand new house and using some alternate form of heat for the room when the furnace is 15 feet away (if I put a forced air duct in the room, it's just creating a sound tunnel to the entire rest of the house). Diminishing the property value along the way.
  • Like
Reactions: Who
redking
Sounds like most of us guys trying to do this at home should maybe shoot for "sound attenuation" rather than "sound proofing". ie. try to knock the sound dispersion down by 75 - 85% rather than shoot for 100% at twice the cost. Is that a fair way to describe it? @Freddy G @Norton
ehb
Chief Discombobulator
Nice blue shipping blankets at Wally for about five bucks....
  • Haha
Reactions: Who
ehb
Company I worked with some years back had a 'dead chamber'... A real one.....
The average person would probably go ape shit in less than a minute or two..... Big time urge to get the hell out... Your brain screams GTFO....
  • Wow
Reactions: Who
Freddy G
Depends...low freqs are the hardest to attenuate. So a bass amp is going to bleed out unless you do a proper soundproofing.
At home I simply use my cellar for an iso room. It works fantastically well. The whole thing is cinder block.
redking
i don't think a bass amp will ever be played live in my room. Best case scenario I would envision a live drum kit, live acoustic guitar and vocal, the occasional miked guitar amp but mostly impulse responses, and bass will most certainly be simulated all the time. The drum kit would be my biggest noise maker. I would want to block as much of the drums as possible from exiting the studio space, and I would want to block as much of the furnace / air conditioner, walking, dog barking etc noise from the rest of the house from coming in.
My biggest problem is being a Mike Holmes fan, so I always want to build something 100% more than what it needs which makes all my desired projects so expensive LOL!
  • Like
Reactions: Who
Neffco
Man, thanks for all the replies. I guess more information I didn’t add would be that I can be as loud as I like where I’m at. Wouldn’t have it any other way. Keeping noise out is an issue as I am on the main drag. My Proposed middle Room I can do a full room within a room. I don’t want to go brick though. I just got off work and need to re read this whole thread. Work sucks. I wanna rock. I have been buying all sorts of stuff for the studio that I haven’t even set up. When I’m off this work project I’m going to start building the room within a room.
