I recently got an unfinished Tele neck from Musikraft and I had them include Klusons to save me the trouble of drilling the holes for the tuner screws, since I was planning to buy Klusons anyway. Unfortunately, the tuners came installed, the screws were in very tight and unlubricated, and as I was removing the tuners the head of one of the screws snapped off and the shaft is now stuck in the hole. There is nothing left to grip. This is the screw at the end of the line.
I've seen the Stewmac kit that lets you cut it out and then plug the much bigger hole you've just made. Is that my only option? Am I crazy to think maybe I can just drill through the shaft of the screw with the help of a guide? Or just leave it in there if the tuner is stable enough with only one screw holding it in?
Thanks in advance for your thoughts.
