Bridge saddle replacement advice
sonar1
Thanks for that link!
I want one too.
Had nylon saddles on my CS ‘64 SG and loved them.
Over the years I’ve used quite a few nylon saddles for ABR-1 bridges.
I like them especially for taking a bit of “ping” out my trebles when I want a smokier tone.
Stinky Kitty
I really like them on my R8. Match up nicely with the nylon nut.
I just recently put them on my 335 as well.
Edited to add: The R8 saddles are individual saddles swapped out for the original ones on the stock bridge. The 335 unit is the Kluson USA Non-Wired ABR-1 Tune-O-Matic Bridge Nylon Saddles Nickel KABRNWN-N
Roxy13
I have one of the Faber bridges with nylon saddles. Are the TonePros ones pre-notched? I ask because nylon is a real pain in the butt to use nut slotting files on. I was quite surprised, thinking it would be really easy and it absolutely was not!
Uncle Vinnie
Good question, and yes, they are. Had to check because you threw a scare into me.
TonePros TP6G features:
  • Notched ivory-color nylon saddles—soft enough to reduce string breakage, but won't break or disintegrate
  • Nylon allows strings to move smoothly and easily while using a vibrato
  • Open-bottom construction
  • Zamak bridge body with nylon saddles and brass posts produce a warm, rich tone with a softer attack
  • Adjustable with flathead screwdriver
Uncle Vinnie
Ordered it today. Will report back when it arrives and is installed.
Uncle Vinnie
Well, the new bridge arrived today. As advertised the saddles were notched and it was a nice close-tolerance fit, drop-in replacement for the Nashville bridge. Well made. I need to do a set up and then give it a whirl.
I'll report back.
Central Scrutinizer
Yes, would like to see your report.
Only have one guitar with nylon saddles, a ‘71 Deluxe.
I do like the way it sounds.
Seems to allow smoother bending, which is probably all in my mind.
Uncle Vinnie
Probably be a week or so before I get to the set up. I'll try to make a vid and post it as long as wifey's honey-do list isn't too long. :fingersx:
Uncle Vinnie
Finally got around to measuring the string height with my feeler gauge. The 6th string (low E) is sitting > .035" above the 1st fret. No wonder I have to use clamping force to press down the strings when playing on that fret.
I measured the same string on my Deluxe and it's a shade under .015".
I'm ordering the files and I'm going to have a go at it very carefully and deliberately. Can't wait to see how this changes the action and the setup geometry when I'm finished.
I'll report back.
