Tonemeister
- Joined
- Jan 16, 2013
- Messages
- 965
- Reaction score
- 495
I believe my bridge posts are placed too far back, at the factory, and therefore my scale length is off. I have to have all but the Low E string saddle full forward. I can't actually even get the A string to intonate.
Here's some background.
Bought the guitar new from Sam Ash a couple of weeks ago. It is a Chris Cornell Sig ES335 Dot with Bigsby. Absolutuely awesome guitar. Have not been able to get the guitar to stay in tune at all since I bought it. Tried filing the nut, lubing nut and saddles etc. Didn't work. Then tried going up to 11's which is a supposed better gauge for the Bigsby. Still no dice. Finally resorted to getting a TonePros roller bridge. I widened the nut slots more aggressively this time. In addition I added a little teflon tape to the bridge posts in order to firm that up more. There was a bit of wiggle prior to that. I also adjusted the truss rod to make the neck perfectly flat with less than a mm of relief at the 12th fret. Now I am in a good place with the guitar staying in tune and the guitar seems louder, acoustically, than it did before the mod. My problem is that when I measure the length from nut to the front edge of the 12th fret, I get the same measurement from the front of the 12th fret to the high E saddle when it is all the way at the front of the bridge. This leaves no room for adjustment on most of the strings and in a few cases leaves the string flat at the 12th fret , even though the saddle is all the way forward. Does anyone know how to fix this without relocating the bridge posts?
