How would you fix the over scraping?Take a piece of dowel.
Drill through the dowel about 1/4 down from the end
take a thin saw and cut down from the top about 1 1/2 inches, 90 degrees from the hole you drilled.
Insert a single edge trapezoid--shaped razor blade in the slot.
Put a small screw that's long enough to go through both sides of the hole, use it as a set screw.
Push the razor blade through the slot in the dowel so that about .060 is exposed, just the size of the binding.
Set it in position and tighen it up with the screw.
You can make this quick scraping tool in less than 5 minutes. Just run it around the perimeter of the body, let the blade scrape the binding top ledge.
Are you talking about that divot in the pic above?How would you fix the over scraping?
I was thinking light and thin color coats just on the edge. Maybe even shield most of the top with a piece of cardboard held just above the surface.
LOL, I thought the same thing. One of those photos you can see either way.NM, the guitar body is black and that is how they are doing it lol! I was totally seeing that picture wrong and thought that was an outside curve and they had the edge of the dowel on top of the guitar body. I feel stupid now.
Maybe I need my eyes checked again, but I'm still not seeing any "over scrape".View attachment 502881 Here is the edge. It is a burst finish.
Hi JKSo, it veered over the maple in a couple of spots.
Is my only real alternative to sand back and redo the color coats?
thanks all
