Tonemeister
- Joined
- Jan 16, 2013
- Messages
- 965
- Reaction score
- 495
Yup, another one of these threads.
I have an ES335 with a B7 on it. From day one it has not returned to pitch for me. I have refined the Gibson stock nut. Swapped out to a roller bridge. Went to a TUSQ XL nut. Nothing has really worked to provide stability and return to pitch in the Bigsby system. The only thing that did work was when I removed the tension bar. The B7 was smooth as could be and I could wail on the bar (as a test and not in practical application)and it would stay in tune. This is how I have eliminated the nut and bridge saddles from the equation. The only problem was I was getting nasty harmonic overtones from the freely vibrating string length behind the bridge. Unfortunately it made this solution nonviable. I am convinced it is something in the mechanical makeup of the B7 which is causing me grief. I removed the tension bar , once again, to see if I could smooth out the points of friction. I'm not really sure how to do this though. Will sandpaper do it or do I need tougher stuff? Also is there something in the cup and spring design that could be getting stuck and not allowing the recoil of the spring? I'm going nuts. I will not accept the answer "Bigsbys have these issues and you just gotta deal with it." I've seen many a player beat the hell out of them and stay in tune so I know it's possible. I also am proficient at cutting nut slots and keeping them smooth and lubed and all the typical answers one would suggest for tuning stability. Come on you Bigsby Wizz Kids. Help a brother out.
