Bigsby for Les Paul Junior
timjwharton
Hi all - want to fit a Bigsby on my LPJ and my original idea had been to fit a B7 with the Vibramate no-drill system. Trouble is that fact that I only have a wraparound bridge means I can't do that. Are there any other no-drill possibilities, or do I have to buy a 'horseshoe' and get drilling? Thanks!
MSB
B6, with a B3 endplate and vibramate "plate" at the strap button. No drill
timjwharton
Thanks. Just to clarify, that's the B6 on the right, and the B3 with the shorter endplate on the left, yes? Is it easy to swap the endplates out? And can I continue to use my wraparound bridge?
MSB
Yes, to all. The B6 endplate will be too deep for a LP, hence the B3 endplate swap. Look at towner.com for a few of the smaller details. Or keep asking here. I’ve done more research on the subject than I’d care to admit, but it’s an easy mod/swap
MSB
Swapping endplates is a tension pin that needs to be punched out
timjwharton
And is a new pin easily fitted to the smaller endplate? (Happy for others to chime in - don't feel you have to respond MSB)
Christosterone
Just saw this thread...everything said is correct
A much less complicated solution would be to use a B5…
I quite love them and they can be fitted with a vibramate bracket so no drilling required
timjwharton
Yes, I like the B5s, but I only have the wraparound bridge (and no stopbar), so no holes to fit the Vibramate bracket...
Christosterone
Oh i didn’t realize that....I’ve gotten dumber of late :h5:
here’s my b7 tail on an es....I have all b7 and b5 models
the B7 tongue would fit too
-chris
MSB
i misspoke, its townerusa.com. its pretty easy
should give you an idea of what you're in for.
if you wanted to space it back for some reason or just get the flat plate
