Mighty kind of you to think of me. @nicolasrivera posted a great demo of my Greeny Burst / Peter Green PAF Humbucker Set on YouTube. Description / specs are in the video comments.
??? ExplainNo SD appreciation here? He wound Peter Green's pickups himself. And you're referencing other makes and models. Zero cred. Zero.
Step away from the crack pipe....No SD appreciation here? He wound Peter Green's pickups himself. And you're referencing other makes and models. Zero cred. Zero.
So what did you get?looking for the closest set to Peters, been thinking about Seth Lovers,Seymour Duncan 59s,Bareknuckle PG set, Lollar low wind PG pickups. Any recommendations thanks
I have an old Les Paul with Seth Lovers as well. I also flipped the neck magnet a couple of weeks ago and the guitar now nails the Peter Green oop sounds in the middle switch position, with many variations available with minor adjustments to the two volume controls. Just what I was hoping for. Cost nothing but 15 minutes and a string change. Easy to reverse but I'm not planning to change it back. I'm thinking any low wind PAF style pickups, especially if unpotted, would work great as well.I had a Seth Lover set and just turned the neck pickup magnet around
Sounded great but I put it back standard as I prefer the sound that way
