Did you have the Holy Diver in your Les Paul? (assuming you have one) Was the True Grit in your LP?One of my favorites, I had one in a guitar for a while. Ultimately I liked the True Grit a little bit better as it's less compressed, but the Holy Diver sounds very good for a higher output pickup! I like it better than a JB and Suhr SSH+, for instance.
No, these were both in a Mayones Regius (neck thru, Fender bridge spacing and scale length).Did you have the Holy Diver in your Les Paul? (assuming you have one) Was the True Grit in your LP?
I have one LP that sounds best with a JB over anything else I try. Maybe the Holy Diver or True Grit would work.
