Average Weight of The Les Pauls on This Forum
How much does your les Paul weigh?
  • 6 Lbs.
    Votes: 2 1.3%
  • 7 Lbs.
    Votes: 11 7.0%
  • 8 Lbs.
    Votes: 50 31.6%
  • 9 Lbs
    Votes: 84 53.2%
  • 10 Lbs.
    Votes: 32 20.3%
  • 11 Lbs.
    Votes: 8 5.1%
  • 12 Lbs.
    Votes: 0 0.0%
  • 13 Lbs.
    Votes: 3 1.9%
  • Total voters
    158
Gtarzan81
I have a Gibson Studio that's chambered, an ESP, and an Epi. Despite being produced about 15 years apart, all weigh right around 8.5 pounds. Go figure.
wader
My 2014 Gibson Les Paul Standard has "modern weight relief" an weights 8 lbs. 11 oz. which is a good weight and feels balanced. My two 2011 MIJ ESP Elcipses weigh ~8 lbs and ~10 lbs (one light with a thinner body and one heavy with full thickness body). I mostly play Gibson Explorers and I have an '82 that's pretty heavy, I estimate over 10 lbs.
fred-paris
My current Les Paul guitars are the following:
- 2012 Black Custom 4,595 kg ==> 10,13 lbs (with Tyson Tone pickups, it was 0,20 lbs lighter with the original pu...)
- 2009 R6 Goldtop 4,126 kg ==> 9,09 lbs
- 2014 R9 Southern Rock Tribute (#88) 3,865kg ==> 8,52 lbs
- 2007 Epi Zakk Wylde Bullseye 4,434 kg ==> 9,77 lbs
A few Les Paul that I've had in the past and for which I kept the weight:
- 2007 Custom ri68 4,435 kg ==> 9,77 lbs
- 2011 Standard 3,914 kg ==> 8,63 lbs
- 1997 Classic 60 4,1 kg ==> 9,03 lbs
- 1981 Deluxe 4,474 kg ==> 9,86 lbs
- 1991 Deluxe All gold Hall of fame 5,2 kg ==> 11,46 lbs ( that one was very heavy. A real pain to play even seated.)
- 1989 Standard 4,7 kg ==> 10,36 lbs
- 1996 Studio Ebony / GH 4,5 kg ==> 9,92 lbs
captdan61
I have one that has P -90's it weighs 10 pounds. And my R9 weighs 8.5 pounds. I jave esquire that weighs 6.2 that ive been playing alot.
James R
I have 3.
A ‘12 Traditional+, ‘13 Traditional, and a Sig T.
According to my crappy luggage scale they all fall between 10 and 10.5 lbs.
I never knew that, I had to go check after reading this thread.
Paranoia
There's something wrong with the scales I used, I somehow doubt my LP is 5lbs :p
I measured the left one (2012 LP Trad) once before though and it came out a clean 10, and my other one (2015 LP Trad) is only a fraction lighter, so let's call that a 9...
trapland
my R7 goldtop weights 8 lb 15 oz I call it 9.
My R9 weights 8lb9oz,
my Es-335 weights 7lb 11oz
and another 12 oz if I put the bigsby on for 8lb13oz
Another 335 that weights 7,13
As ES-175 at 5 1/4 pounds. Its like playing a cloud.
My strat is 7
My Telly is 5
I has an Es-Les paul was right At 6lb
And Es 339 that was 7
BADMAN67
Too Heavy! Thank funk its weight relieves! Must admit I love my Standard, but when I play with the boys I take feather weight les paul junior or my old Charvel. I am 50 and a bit worn ha
efstop
'13 '50s Tribute 9.2 lbs
'17 Tribute T 8.4 lbs
DarrellV
'I'm not stupid, you just don't understand....'
That mil spec cold war surplus bridge is good for a pound itself. :p
Yeah Buddy! Back when they made things RIGHT! Quality materials, not Chinese pot metal! Hefty!:thumb:
