Are these CAPS right ?
p90rules
So I've got a 73 Les Paul Custom on my radar that is supposedly all original, so just wanted to check if these caps look correct.
Cheers guys
Dilver
Not sure if they used others, but most 71-74 Les Pauls I’ve seen have ”black beauty” caps.
They changed in 73 sometime. The real 74's have a brown ceramic cap which stayed the same for a while. There was a short lived cap in 73 after the black beauty was discontinued but I don't know what they were.
1981 LPC
They're both .022 mfd by the way. Usually they're a combo of 22 and 47 when used with 500K pots / humbuckers.
Are the pots original? I believe lower value pots were used in the norlin era. My 81 Custom had 300K volume and even lower value tone pots.
HardCore Troubadour
There’s a Norlin cap ID by year thread here somewhere….I will look and see if I can dig it up.
p90rules
Thanks for the info guys..Much appreciated
mudface
Shaw Bucker
As mentioned already,.... most 1973 Gibson LPs had "black beauty" Sprague capacitors like these...
1973 Deluxe
Gibson_Les_Paul_Goldtop_retrofit_based_on_1973_Gibson_Les_Paul_Deluxe_(SN_620310)_control_cavi...jpg
Though the caps in the OPs guitar could be original,.... just because i have never seen these before doesn't mean Gibson never used them..... this '73 to '75 period the only thing consistent was the pots.... even the wire channel bounced around.
Another possibility is that someone replaced the Spragues to resell and used the yellow lead sleeves to resemble originality.
billyhandyjunior
Any idea what’s going on here with this all original (supposedly) 1974 Les Paul Custom.
p90rules
So should I assume the caps in the 73 are probably not original?
mudface
Shaw Bucker
Everything else seems original,.... pots, solder joints, and wiring..... if the caps are not original i wouldn't sweat it. Easy to replace without any harm. I wouldn't touch them if the function like they should as they very well could be "original".
It wouldn't be a deal breaker for me.
msalama
AFAIK, Gibson also used German Ero-Fol and Ero-Fol II caps up to '74 or thereabouts. Or am I mistaken?
HardCore Troubadour
