decoy205
- Joined
- Sep 10, 2007
- Messages
- 8,394
- Reaction score
- 2,488
We moved into a house this past July (We live in Central Jersey) with an older above ground pool. I believe its 20'. My guess is that the frame is either late 80's or early 90's.
The owner kept very good care of the house and I'm sure that applied to the pool maintenance. He left records of manuals and receipts and it looks like the liner is from May 2020. So the liner is only a year and a half old.
I haven't had a pool since i was a kid. We had an 18' above ground very similar to this one but by the time i was old enough to understand how to care for it, my dad had already had it removed. So this is really my first time caring for a pool.
I covered the pool in the fall following all the usual steps. I lowered the water to below the lowest inlet point, set up the air pillow, and covered the pool clamped it down and tightened the steel cable.
One mistake I knew I made was not using ropes to keep the pillow centered. By November the pillow had moved to one side of the pool. I had used a pump I got from the pool store to empty the water down to about 1.5" in the cover, and then pushed the pillow back to the center.
Before Christmas I tried the pump again to get more water out but the cheapo pump wasn't working so I gave up and left about 3-4" of water in the cover.
We didn't have much rain but it snowed last week so I went to check the pool today. The water level appears to have dropped significantly. I had about 3.5' of water when i closed it and now it seems to be around a foot? I can't tell exactly with the cover on. I'm worried there is a leak. Being the liner is only a year and a half old and we only had 3 or 4 days of frost so far this year i don't get it! The water in the cover is now frozen. By Wed it should be warm enough for me to pump out the cover again and I will definitely do that as I'm sure we'll get more rain or snow.
My questions are:
1. Could the liner have been damaged already causing the leak, or did me not properly centering and securing the pillow have caused frost to make a hole somewhere in the cover?
2. Should I be adding more water to the pool to get the level back up?
3. Should I empty the cover completely, uncover, add more water, reset the pillow this time tethered to the center and then re-cover the pool?
I'm concerned as we he have just started winter and I don't want to destroy my pool on the first season.
Any advice is appreciated!
-John
My questions are:
-John
