any locally available fret pullers
joesatch
I have access to Home Depot, Lowes, Harbor Freight in my area. Any flush end cutters/ nippers suitable for pulling frets? Doing the refret over the weekend so i cannot order online.
Skyjerk
Meatbomb
if you have a grinder of any type you can just buy some standard nippers and grind the top flat until the cutting edge is flush. You could even do this with a good file, although its more work...
Caretaker
And if you heat the frets with the tip of a soldering iron they come out a LOT easier.
It helps break up the glue if any was used.
jvin248
You can also use diagonal cutters after clamping and drilling a hole large enough for the fret to go through near the hinge as you work across the frets.
+1 on heating the frets before pulling, it will dramatically reduce tear-out.
Ripthorn
I bought small harbor freight nippers and ground them down to be flush cutters. Took all of 5 minutes and have served me well for years.
joesatch
yup i'm gonna get a couple small harbor freight nippers and grind them. Thanks!
