Amp Whiz Zimmerman Discusses The Physics And The Myths Behind Electric Guitar Amps
VictorB
Strafford amp whiz Zimmerman discusses the physics and the myths behind electric guitar amps | Burlington Free Press | burlingtonfreepress.com
When music lovers in music-savvy Vermont listen to live acts, as often as not, they’re hearing them through amplifiers and speakers. Even so-called acoustic sets often rely on a house PA, right?
Amps are the unsung heroes of electrified music, says Strafford author, musician and amp builder Dave Zimmerman. The best guitarists, he writes, skillfully “work” their sound through circuitry; inspired musicians plumb the wherefore of wave lengths and power tubes before hooking up their wah-wahs.
Astute listeners on both sides of the stage might well ask: “What’s shaking behind all those speakers?”
Zimmerman, 46, elaborates in two books he published last year: “The Guitar Amplifier Player’s Guide” and “The Guitar Amplifer Player’s Troubleshooting Guide” (Maven Peal Publishing).
Burlington Free Press: For beginners — could you explain what makes what we often think of as great electric guitar (and amp) tone?
Dave Zimmerman: When Leo Fender made the first amplifier in 1946, he borrowed the entire design from The RCA Receiving Tube manual, which was published to help manufacturers incorporate RCA’s vacuum tubes into their products. For consumers, this meant radios. So, the original amplifier design (which hasn’t changed a whole lot since 1946) assumes the input signal is originating from a radio.
When you turn a volume knob up loud enough, an amp stops getting any louder; it starts distorting, that is, it adds something to the sound. The right kinds of distortion, in the right amounts, is that magic behind “great” tone.
A little bit of added sound, and the amplifier produces jazz and country tones. A lot of added sound, and the amplifier gets into classic rock and roll tones.
BFP: Tell us more about tubes.
DZ: Classic amplifiers (Fender Deluxe for example) use tubes and only tubes for all of the amplifying functions in the amp. But tubes are heavy, wear out, can be easily broken, are large and hot. So manufacturers started replacing some or all of the tubes with transistors. While transistors are light, don’t wear out, difficult to break, are small and don’t run hot, they also can’t distort like tubes do.
BFP: Any cool, newer stuff?
DZ: More recently, amp manufacturers have come out with amps that digitally model the classic tones produced by cranked tube amplifiers. These newer amps are appropriately called “modeling amps,” and use a combination of a computer and transistors. While the computer section has come a long way and sounds pretty good, the transistor section still can’t distort like a tube does. When it’s time for the real deal, you still need a tube amp turned up loud!
It can be really frustrating for amateur guitar players to duplicate the tones they hear on the radio and on albums because they simply are not able to play in a room where they can really turn it up.
BFP: Any common misconceptions among experienced musicians about their amps?
DZ: Musicians pay way to much attention to their guitars and not nearly enough attention to their amps. A cheap guitar plugged into an expensive amp produces far better tone than an expensive guitar plugged into a cheap amp.
You’d really be surprised how many players want to sound like (Led Zeppelin guitarist) Jimmy Page, yet believe that Page’s sound comes only from the equipment he used. If I were able to get my hands on the identical rigs he used, I would still never sound like him in a million years. A guitar’s tone is ultimately in the player’s fingers (touch, etc.) and Jimmy Page is an extremely talented player who practiced night and day.
BFP: You write in your first book that a player like B.B. King can get great sounds out of almost any amp.
DZ: His guitar is certainly a large part of it, but I would say that well over 80 percent of his sound is right from his fingers and his ability to control the guitar and amp he is playing.
I think a good electric guitar should sound good unplugged, so you can learn about guitars first of all. Secondly, playing unplugged makes you really work those strings for sustain instead of relying on an amp to do it for you. Thirdly, turning off the distortion makes it so you can’t hide behind a wall of fuzz. You have to put yourself right out there and any problems in your technique are going to come right through, which can be more than a little humbling.
BFP: A little background: When did you play your first electric guitar? Through what amp?
DZ: I first started playing electric guitar in 1978 when I was 14. I had a Gibson “The Paul,” which was their cheaper version of the famous Les Paul. I used a Traynor transistor amp that eventually blew up with smoke, fire, and lots of weird noises — it was great! So I had to start understanding amps because I needed one, and my first tube amp was an old radio that I modified. It sounded pretty nasty but it was fun.
BFP: When did you begin to refine your appreciation for amp sounds?
DZ: I have always been a geek when it comes to guitar sounds (I have a B.S. and M.S. in electrical engineering), but I really started paying attention to guitar sounds when I was in a band in, and just after, college. We used to record our practices to hear how we were coming across, and it really became apparent to me how much my guitar tone was lacking. I started really going after the gear at that point.
BFP: How so?
DZ: In grad school. I studied chaos theory and decided to use mathematical modeling techniques to analyze the amp Neil Young uses: a slightly modified Fender Tweed Deluxe. I discovered that the power supply on his amp is literally on the verge of coming apart when he is really going after it. That particular amp suits him so well that at one point he accumulated about 450 of them, trying to find a suitable replacement.
I went on to patent circuits that allow players to create that “cranked” distortion tone at lower, more reasonable levels.
BFP: Tell us about your inventions.
DZ: The circuits I developed allow a musician to control two aspects of amps they could not before. One knob lets you control how many watts (and therefore the overall volume) that the amp is capable of making. So, you can turn your amp up in the old-school sense, but reduce the volume so you can stay in the same room. For example, one of my amps let’s you set the wattage it is capable of producing from 1 to 140 watts.
The second knob controls how the amp behaves when you are playing it cranked up. This knob came out of what I learned studying Neil Young’s amp.
BFP: About noise: Do you wear earplugs?
DZ: I have to wear them when I test the amps I build (Maven Peal Instruments, Inc.) — I love my ears and want to protect my hearing. However, I prefer not to wear earplugs when I play, and with my amps, I don’t have to, because I can turn them down and still get good sound.
BFP: About peace and quiet: Any advantages/disadvantages to living in central Vermont?
DZ: The are huge disadvantages commercially to living in Vermont when it comes to the amp business just because there not as many musicians around as in say New York or L.A. However, there are a large number of guitar players in Vermont, and they have been pretty supportive of me. On the plus side, I can play as loud as I want, whenever I want.
BFP: How so?
