Anybody?I was wondering if anyone had done any research into the difference between the cast zinc stop tailpiece and the aluminum one?
How is the tone different? Sustain? Bass response? Treble?
Because there is none.I switched to an aluminum one. I noticed absolutely no difference in tone.
If I just played at home, I would probably never notice any difference for myself. When I play one of my LPs on stage for a 4 hour gig with a hard hitting drummer, bass and a singer, it's pretty easy to notice differences in sound, when changing things on the guitar.Because there is none.
Placebos are a powerful thing.If I just played at home, I would probably never notice any difference for myself. When I play one of my LPs on stage for a 4 hour gig with a hard hitting drummer, bass and a singer, it's pretty easy to notice differences in sound, when changing things on the guitar.
I can easily tell a difference in sound when changing to an aluminum tailpiece. I like the sound much better. I have changed all my LPs to aluminum TPs.
Tone is in your fingers (and pickups and amp). That was a nice made up story you told about them trying hundreds of tailpieces, but it's complete bull****. Please find any of the musicians you mentioned that have a "good sense of tone" attributing their tone to aluminum tailpieces... Post that when you find it.I can hear a big difference with the aluminum ones, but like with a lot of these incremental improvements, I needed someone to show me exactly what to listen for, before being able to first, hear the difference, and second, to decide which I personally liked best.
I think one thing to bear in mind when considering these tone monsters going by the name of Lester, is that they were designed by guys with incredible hearing. Seth Lover & Les Paul, for example, had awesome ears (performance wise... I've never really looked at them aesthetically). I'm sure they tried hundreds, if not thousands, of variations before deciding on which combination sounded best. After that it was just rinse and repeat. They didn't need skilled laborers who understood the intricacies of sound... just someone to paint inside the lines.
If you can put two virtually identical sounding guitars side by side, and make changes to one and compare it to the other, you can notice a helluva lot more than by changing the tailpiece on one and comparing it ex post facto by memory. I wasn't there, but I tend to believe they tested a bunch of different tailpieces before deciding on the aluminum. I'm sure they tested various caps, nut and saddle variations, pots, positioning, bridge materials, etc., ad nauseum, before deciding on their winning formula. And while it wasn't accepted as the de facto king of the hill until musicians with an equally good sense of tone (Clapton, Richards, Green, Allman, et. al.) recognized their superiority. I get a good laugh at the hacks that come along in these forums spouting off about how they know more about tone than these guys, and even though they may not be using them any more (for whatever reasons) they were still used to create some of the greatest music in history... IMHO.![]()
Obviously something you will never understand... I'd respond to your other ignorant crap, but like virtually everything else you have posted to date, both here and elsewhere, that really is all that it is, and it is quite undeserving of even the slightest response or acknowledgement.By the way - what the hell is a "good sense of tone?"
There are a lot of elements in guitar tone. You will need to educate yourself considerably in this department.......the whole is the sum of the parts in all cases.Tone is in your fingers (and pickups and amp). That was a nice made up story you told about them trying hundreds of tailpieces, but it's complete bull****. Please find any of the musicians you mentioned that have a "good sense of tone" attributing their tone to aluminum tailpieces... Post that when you find it.
And how do you claim to know that Seth or Les had better than average hearing? You made that up.
It's easy to notice differences in sound when you just shelled out $60 for a tailpiece. You could convince yourself of anything after that. Creamtone has some $70 knobs as well you should see what those do for your tone...
You are much more patient than I...There are a lot of elements in guitar tone. You will need to educate yourself considerably in this department.......the whole is the sum of the parts in all cases.
In that way, the change of 1 part can have a big effect.....or very little, or none depending on the whole.
The electric guitar is a physical or mechanical device long before it becomes an electromagnetic one. Anything which enables the string to be held at tension (wood/hardware/etc) will have a major to minor influence on how the string vibrates. Only after this does the pickup come into the equation.
This is the way it is........it is now up to you whether you are able to understand the complexities - then we can move forward.
Kudos for your efforts...^ I've had a lot of these 'caveman' type arguers to deal with in the past......you know the ones that try and 'club you over the head' with their flat denials until you submit.
Its not a position arrived to by virtue of any intelligence or application to the issue at hand. Its simple stubborn belligerence.
We'll see if there is any light at the end of the tunnel here, see if this one can actually come up with any semblance of a structured argument. Judging by this thread and the other he was in I doubt it.
Not that the result is in any doubt.....its just a case of whether he can swallow the pride enough to actually listen to arguments.
