vincenz
- Joined
- Nov 21, 2007
- Messages
- 38
- Reaction score
- 44
I started up with this reflexion:
I need a tone control to reduce treble on the bridge pickup, indeed, but what I really need on the neck pickup is a tone control to reduce bass.
In addition, I wanted to solve definitely the problem of treble loss when lowering the neck pickup volume.
I am used to play some dynamic single channel amps (Trainwreck clones and Reinhardt Sultan) and I manage all sound changes from the controls of the guitar. I like to play main riffs and leads with the bridge pickup at full volume, I switch to the neck pickup with the volume rolled down in order to clean up the things.
I am trying out some different component values with this wiring for a couple of month and now I am fully satisfy with this set up.
The bridge pickup section is wired in a classic way, '50 style, however with these distinctive features:
Volume control: I finally found the best volume pot for me. I tried the RS superpot, Dr Vintage, even the expensive Alessandro, all of these are great products. Then I bought the CTS "True Vintage Taper" (TVT) from crazyparts.de, value slightly above 500k and the perfect taper for me.
Tone control: 500k linear pot and Luxe .022uF cap.
The neck pickup wiring is more specific:
Volume control: 1Meg audio pot with a treble bleed circuit (.001uF cap and serial 230k resistance). I am using a 1Meg pot instead of the conventional 500k for these two reasons:
First, to increase the resonant peak, so the neck pickup sounds brighter and clearer at full volume.
Secondly, to improve the curve of the pot with the treble bleed.
Tone control: 1Meg linear pot and "bass-cut" special circuit with .001uF cap and grounded 1Meg resistance.
Here is the diagram :
