chasenblues
- Joined
- Apr 2, 2007
- Messages
- 21,316
- Reaction score
- 32,250
When i nod my head you hit it ok....
....I do feel compelled to point out that adjusting the rod does not always produce an immediate result. It can take minutes before you see it.....
Turn it to the left. Which left, this left? No, the other left!![]()
I've got a Telecaster that is not showing results immediately. I adjusted the rod, apparently to its limit, and slackened the strings, and it is STILL not coming out of it's 'bow'. I'm going to try lighter, 9 gauge strings if it doesn't straighten out.
I've got a Telecaster that is not showing results immediately.....
-=[Shifty]=-;866648 said:....Is it right to assume that the neck has 'front bow', then?![]()
Too much 'relief', and tightening the truss rod didn't make it 'flat'....
-=[Shifty]=-;866655 said:Well, if it has too much relief you should try 'loosening' the truss rod....
Loosening allows the neck to bow more, and tightening works against the string tension, thereby taking the bow out. I'm not THAT dumb!![]()
I think my head is gonna 'splode...
....or if it's just not got enough ompfff to counteract the strings.
I think that's the problem I have; the threaded portion is not long enough to bow the neck back enough.
ive had my truss rod slide up before when trying to pull my allen wrench out on an angle, i pushed it back in and it still tightens/loosens and seems to be working even a year later.
So i dunno
take it to a professional and stop messing with your guitar
