Hey guys, looking for some advice on nut slotting. I’m no novice when doing setups and guitar builds but I’ve always sort of lacked confidence when it comes to making nuts. I’m currently trying to make a nut for a Strat type guitar with a 2 point term, this is the first time I’ve worked on a guitar with a term.
The problem I’m having is with the G string. I’m able to get the bass E, A and D strings down to under 0.4mm above the first fret with no buzzing when picked relatively hard. However with I go to 0.4mm with the G it’s hitting the first fret. It almost seems like the rest of the strings when struck are vibrating horizontally and avoiding the the top of the fret but the G ends up vibrating vertically and so creates the buzz at the first fret? Seems around 0.5mm is okay for the G.m string. Is there something obvious I’m missing? Am I aiming too low with these numbers to begin with? Can’t recall having this issue on my hard tail / tunomatic guitars in the past.
For info, the other setup specs on the guitar are 0.25mm neck relief and 2mm height at 12th fret for low E and 1.5mm for the high E.
Cheers
Cheers
