Advice needed with ash
ejendres
Hey guys. I'm building an Ash Telecaster for my bud and included a tummy carve. I used a rasp to rough out the tummy carve and got a pretty smooth curve. However when I sand out the tool marks I'm getting ripples along the grain. Basically the grain is sanding quicker than the rest of the wood. I've re-shaped the tummy carve twice now and tried different ways of sanding out the tool marks and both times I get the same ripples with the grain.
Any advice for avoiding this?
jkes01
Have you tried smoothing with a cabinet scraper?
ejendres
I've never used a scraper and do not own one.
Skyjerk
Meatbomb
wrap sand paper around a curved sanding block or fat dowel. You just need a backing to the sand paper that isnt flexible and wont dig in deeper where the wood is softer. Hand sanding is problematic for woods like that.
ejendres
Thanks Skyjerk, that's a brain fart on my part. I should have done that from jump.
dcomiskey
You can also just use a razor blade. I use them all the time for scraping small areas. Since they’re about 1.5-2” long, they work great for the tummy and arm contours.
LtDave32
Desert Star Guitars
If the wood is indeed swamp ash, then it is very punky, as they say. The grain on swamp ash is always an issue to work with. In my experience, after the filing and rasping has provided your basic shapes, then sanding is the way to go. Take it to 220, then you'll need to start filling that grain. You can make an easier job of it by using a sprayable, sandable sealer at this stage.
tabascom16
You need to do 2 things. Number one, you need a firm backing behind the sand paper like a sanding block, not your hand. Second, you need to sand with the block angled in at least 2 different ways called an "X" pattern. Look up automotive paint block sanding. When the sanding block is constantly faced in the same direction it will make ripples as well. You need to put the block in a slightly different angle to take any ridges out from the other direction and vise versa.
charisjapan
You may want to consider getting one! About the least expensive tool available, it can do a lot of things well. While there is a learning curve to sharpening and usage, it's hard to get much simpler than a card scraper.
LtDave32
Desert Star Guitars
Excellent advice on finish sanding, and I hardly ever see that method discussed.
B. Howard
Ash, especially light , musical ash always has deep grain. This is magnified by the angle across the grain in arm bevels and tummy cuts. This is why Fender developed "Fuller-plast"..... to cut down the grain filling process. Oversanding will make this more pronounced, especially on a curved surface.
