Tweaker
- Joined
- Jan 18, 2012
- Messages
- 2,979
- Reaction score
- 2,229
To you acoustic builders on here, do you incorporate a neck plane into the soundboard (similar to building a Les Paul)? I've been getting my feet wet with acoustic guitar building and am exploring a few different neck attachment methods but I keep running into the same problem. I'm not brave enough to dovetail a neck yet, so I'm working with bolts and threaded inserts for now. (Don't laugh)
With the strings 1/2" above the soundboard at the bridge, the neck is going to require an angle to keep the action correct. But what I'm finding when I try to add a neck angle is that the end of the fretboard raises up above the soundboard. I've only thought of a few solutions to this and I don't like any of them.
First, just glue the fretboard extension to the top. I hate this idea, as it seems like it would stress the fretboard and obviously destroy the flat fretboard plane.
Second, build a taper into the fretboard so the neck sits 90 degrees to the body, and the effective neck angle is built into the fretboard. I don't like this idea because it sounds painful to execute, and in my opinion, look terrible.
Third, build a neck plane into the neck block. I'm not sure I like this or not, as I can't find anything that suggests this is a common solution. I don't like the idea of putting the soundboard through that additional stress. (I realize on the back, the radius can be "forced" so to speak, but there aren't really any direct forces pulling at the back.)
I suppose another option is to build the neck angle into the vertical member of the neck block, so it isn't a true 90 degrees. But that would pull the sides out of square with the top..
What am I missing??
What am I missing??
