Good morning all~ Forgive me as it's been a while since I've owned a LP or similar with a standard 2 p/u, 2-Vol,, 2-Tone setup... It's a Dean Hardtail that has had the original p/u's replaced with some X2N ceramic clones that sound fine, but I sense that something is amiss.. When I'm in the MIDDLE position and I fully back off the volume of either p/u, I lose all volume once either p/u is all the way off. 50's vs. 60's wiring? I read that the 50's wiring helps you retain the tone when you turn down, but will that wiring give me independent Vol control? Maybe a good link or two to some Schematics would be fab!! It's 95 in the shade, so I'm one lazy sod, but thnx in advance....
As an aside, the 10.3K Neck p/u is overpowering the 16.6K Bridge, regardless of how much i compensate the p/u heights,,,??....
