axslinger
- Joined
- Jun 30, 2008
- Messages
- 1,344
- Reaction score
- 300
I am trying to get past a speed threshold that I've reached. I'd like to be able to tremolo pick scales. I understand I need to be able to tremolo pick on one string before I can attempt solos.
For those of you who can do this type of thing, do you anchor your palm on your bridge or do you keep your hand free? Do you let any of your fingers touch your pickguard or if you don't have a pick guard, do your fingers touch the guitar below the high E string? When you move up a scale (across the strings from low E to high E), do you keep your hand arm stationary and just rotate your wrist down toward the high E string?
Where on your thumb do you grip the pick? I get the impression that I should be gripping the pick at the joint of the thumb rather than the flesh part below the joint. I've been told that the picking should be done with just the wrist rather than moving/rotation the pick with the finger and thumb...that the finger and thumb should remain stationary across the strings and the lower strings should be reach strictly by rotation of the wrist without moving the "anchor point" on the bridge/tail piece. My problem with that is I end up picking the 1st, 2nd and 3rd strings right over the bridge pickup and I don't necessarily want that tone.
I really want to get moving with my speed but I can't seem to get past a certain point before everything just turns to shit and gets out of control and sloppy.
Any and all tips/links would be appreciated!
Ax
Ax
