A bad pickup?
california1967
I'm currently running a SD Sh-1 in the neck of my guitar and a SD Sh-4 in the bridge of my guitar. When I first installed the pickups I had a really bad hum/grounding issue and the bridge pickup (SH-4) sounded really muddy. So I decided to upgrade my electronics. I used 500k CTS pots, a .022 Orange Drop in the neck and a .022 Goodall PIO in the bridge. The exact same thing is happening. The Sh-1 sounds amazing, the Sh-4 sounds like crap and a grounding issue exists - when I touch the metal the hum stops. Anyone have any ideas, could it be a bad pickup (I did get them used)?
snaredrum
how good are you at soldering? i've found it's almost ALWAYS my shoddy soldering that is causing the problems...
firesgt911
Yep. Probably a bad solder joint on the ground wire.
b-squared
Where you at in MO? Close to STL? Maybe I can take a look...
BB
california1967
Thanks for the offer BB but I'm in Columbia about 2 hours-ish west of STL. :)
It could always be my amazing soldering skills :laugh2: but I just found it curious that after I replaced all the wire/pots that it has the exact same problem.
I guess I could always just pop in one of my old stock Epi pickups and see if it changes anything.
snaredrum
just redo all your solder points first. doesn't take long.
snaredrum
this is copied from the magnet swapping 101 thread, and is me about six hours ago.
Yesterday, 07:09 PM #19 (permalink)
snaredrum
GibbonsTone Or Bust
Re: Magnet swapping 101
hey man, i swapped the magnet round in one of my pickups, and the pickup now seems a lot quieter. i've checked with the multimeter and the pickup is still showing what it was before. i thought that i may have pulled a solder joint loose whilst doing the swap, but i've checked all the joints and they seem fine.
any chance it's just a hell of a coincidental time for a pot to die?
**never mind - i figured it HAD to be the soldering, so i just redid all of the bridge pup solder. hey presto. phew!
"Rock And Roll is the only religion that won't let you down." - Ian Kilmister
