7enderbird I
angeldeville
A solid body with a P90 and a Bigsby?
Nuthin you don't need...
I’m digging the lefty Tele headstock with that body.
I'm liking it too, but I did have my heart set on a matching headstock/neck paint.... I'd hate to cover all that birdseye...
and the gearless would look funny....
tough call, I'll paint the body and strat neck this weekend, and do another test pic....
angeldeville
fit a neck, mounted the pickup, mounted one of the flush mount straplocks, wasn't drilled for the ground so I did that, found an area in the heel I want to fix.
I'll fit the pots and jack and possibly the bigsby tonight.
gearless tunas should arrive tommorow, and I'll fit those and paint.
decals and clearcoat over the weekend.
angeldeville
12” radius bridge to 9.5” radius fretboard, intonation, electronicles yet to go..
figuring out how to set up and use the gearless tunas is fun, still got one I set wrong.
nut needs to be replaced, it’s made of case hardened dildos.
angeldeville
Even after checking the wiring 50 times or so I had wired the jack backwards…. It sounds much better the right way..
angeldeville
I ended up slapping on some strat knobs, they work and look fine here…
I had also thought to change the cover from cream to black, but I’m really liking the cream with the black knobs.
