78 Explorer tuners help
dbwalker
So I picked up a 78 Explorer that needs a bit of work, at some point the guitar fell off a stand and took a hit on the high E tuner "these are the 6 on a plate" their all pretty worn out reguardless and Im looking for replacements, Klusons 6 on a plate all measurements except plate length are correct, the Klusons are 5 7/8 plate length the original is 6" even, the ends of the plate are shaped a bit different, also wondering if tte screw holes will line up, im wondering if anyone has any ideas on if there is a correct fit after market 6 on a plate for these guitars or any other ideas
dbwalker
Doesn't the Kluson site give the hole dimensions?.
Al
Unfortunately no, they give all the other dimensions but not the screw holes, I think im just gonna buy the klusons and worse case scenario maybe I can switch them on to the original plate, just gonna be a pain to bend all the little metal tabs and resecure them without breaking any
dbwalker
For anyone else looking for the same info: i went ahead and installed the Kluson 6 on a plate tuners, screw holes and all lined up perfectly, only 2 issues with the new tuners, the kluson bushings are a slight different outer dimension "more of a cours thread" so just used the originals with no problem, and as I expected the plate itself is shorter, but all in all they work perfect with zero modifications to the guitar, the more I looked at them I decided not to attempt taking them all apart to use the original plate with the new tuners
