Is that first position marker cracked and maybe even re-glued?
There is a pretty clear line in both pics. Or can the material separate on its own sometimes?
Yeah I contacted the seller and he couldn't tell me all the numbers on the CTS Pots cause of the soldering. All he gave me was 13774.
Does it even matter with the ridiculous asking price???
74/75..The last years of the waffle backs?
And that colour is waaaaayyyyyy too rich! It almost out-tv-yellows a '59 TV Yellow!!!
Wafflebacks are most likely repros as well..NO way it could get that yellow and be that gold still..compared to the wear on other gold parts.
I don't know... There's some wear and pitting on the buttons and there's not a ton of wear on the bridge and pickup covers. I think that tailpiece has more corrosive/delaminating type wear on it. IF you take this guitar as 100% original, there's not a lot of wear on it (often the white-to-yellow color variation is partly due to worn-through yellowed clearcoat). All that having been said, the lack of color difference in the cavities doesn't sit right with me. You can't see any outline of the pickup rings in the photos with them off the guitar -- there's no apparent indentation in the finish, zero color difference, etc. That's a spot where something is directly masking the finish at all times, mounted firmly up against it. The only way I could see that all-over yellowing happening is if somebody stripped all the hardware off this guitar and then had it sitting disassembled for several years.
