I thought I told Howard not to discuss religious matters.
..Then he brings up Fender owners.
How accurate are these guns under discussion, or for that matter the 1-hour homebuilds you're mentioning here?
Ignorant as I am, I'll take your word for it.
What concerns me is whether these could be used for one-off jobs, which is why I was asking about accuracy. How accurate are these guns under discussion, or for that matter the 1-hour homebuilds you're mentioning here?
I'm not trying to be a jerk, just trying to gather info.
Okie, then... here's the original FP-45 (the WW2 metallic version) in all its glory. The 3D weapon under discussion currently is basically just a plastic knockoff of the metallic type:
This was a single-shot pistol, designed to be air-dropped into Nazi-occupied areas and distributed among those who wished to resist the depredations of the Third Reich. It was shipped with 10 rounds and a wooden dowel to eject the expended shell casing from the weapon after it was fired.
It was chambered for .45 ACP.
The maximum effective range of this weapon was listed as a whole 8 feet. But mind you: they weren't saying that you'd be shooting tight groups with this one at 8 feet-- just that one could reasonably expect to hit a human being up to 8 feet away with it.
The plastic model probably features all the same performance, but isn't stout enough to handle .45 ACP ammunition.
Though the original idea was to air drop tons of these, the weapon was also designed to be very easy to duplicate by those with access to common hand tools and half a lick of sense. As you can see, it was barely more sophisticated than some of the zip guns that Cooljuk posted photos of earlier.
The recommended procedure of use with this weapon was to walk up to an armed occupier (or one of their hated sympathizers), push the thing up against the poor bastard's noggin or neck, and to let him have it. Following this, the idea was to grab whatever weapon the person happened to have on him and scamper away with it for further use against the enemy. A little comic book pamphlet to show how to use it and where to shoot somebody with it was shipped along with the weapon, the extractor dowel, and the ten rounds of ammunition.
Crasseux boche! Vive la libération!
It was only in production for 6 months in 1942, to the tune of 500K units. Despite the large number of 'em slapped together, not so many were ever air dropped. It seems that Ike and most of the other big military shot-callers didn't see the value of the Liberator pistol and thought that the Sten gave you more bang for your buck.
It also appears that those guys figured that somebody could do the same job with a kitchen knife, or a rock in a sock, or even a sharpened toothbrush handle, like the ones prison inmates occasionally murder one another with.
However, the OSS did see that the thing might be useful, and apparently sent some 25,000 of the little buggers to occupied Europe, where it was documented as having been used at least once to knock off an officer of the Gestapo. Other than that, it doesn't seem to have a well-recorded or distinguished track record as a weapon of war... or even of insurgency.
I don't know if it's still there, but back in the Seventies there was a somewhat similar weapon on display in the JFK Special Warfare Museum at Ft. Bragg, NC. This was a cast epoxy firearm-- a gun that was literally made out of hardened glue. It was a double-barreled weapon, sort of like an over/under derringer.
This weapon didn't even use metallic cartridge cases for its projectile. Instead, one packed guncotton, standard smokeless powder, or even black powder into the barrels and then loaded a round lead ball of about .32 caliber into the barrels and packed the mess down (with a leftover Liberator ejection dowel, perhaps). The barrels were reinforced by aluminum tubes that looked like they might have once been the barrel of a fountain pen, or maybe an automotive radio antennae.
The ignition system wasn't a cartridge primer or percussion cap, but was instead a small battery, a couple of wires, and a light bulb's coil filament that was threaded through a small hole at the base of the barrel. The trigger was a simple on/off push button. When you pressed the button, both barrels went off at once.
Pretty neat, eh? But as was the case with the Liberator pistol (and the Welrod, and a couple of other field expedient weapon types) nobody much seemed to wish to use it...
What the weapon that is the subject of this thread happens to be is nothing more than a 3D printed, plastic version of the Liberator-- except that the cartridge type that would be suitable for use would be something *very* low pressure, like a .25 ACP, a subsonic .22 short, or something along those lines.
Also: thank you for the compliment!
--R![]()
The average handgun shooting occurs at a range of less that 10'. Furthermore, if somebody has decided to employ a single shot pistol, they aren't getting into a gunfight, they are executing someone whom they have either approached completely by surprise, or have already subdued or cowed into compliance. Accuracy would be a trivial concern.
I'd rather hear from ya twice than not at all.....Oh good. It’s the Waterfront Double Post Special.
Sorry guys, this is gonna be happening a lot.
Take "gun" out of the equation. What if this were an effort to take information away for some other purpose.
Like artificial limbs, but the AMA doesn't want the info out there.
DIY plumbing/electrical fix, but the plumber/electrical unions are opposed.
DIY auto plans, but GM/Ford/Chrysler are opposed.
Youre equating a plastic firearm to nuclear weaponry?You're equating a print at home firearm to an artificial limb?
What about nuclear suitcase plans? Or plans for the Grand Gulf 1 power plant? Or the nuclear missile codes?
Obviously there are legitimate reasons to censor information.
Those people have been LEGALLY found ineligible for firearm ownership. Although I disagree with the felony thing. Once your time is served your rights should be reinstated......that aside if you can legally own a firearm you should be able to legally own ANY firearm. Our firearm laws are ridiculous. I cannot own a short barreled shotgun BUT I can buy a handgun that shoots shotgun shells...... this is just more hand wringing and fear mongering.So anyone can have a firearm right? The mentally ill. The deranged. The convicted felon. Children. Fender owners. Anyone.
Obviously not. The issue is slightly more complex.
i)
ii) I'm showing that some information is important to censor.
Wow, giving away more liberties...no thanks!
So keeping the masses ignorant in order to keep the masses controlled is ok with you?i) It's a demonstration of hyperbole. Firearms are weapons, meant to kill things. Although you can kill someone with an artificial limb too, that's not the intended purpose.
ii) I'm showing that some information is important to censor. You can try to spin this any way you want, but you agree with this point too. So we both agree that in some cases censorship is required, now it's just a question of where we draw the line.
You aren't American are you?Absolutely yes, in some circumstances there is information that should be kept under wraps.
