H.E.L.Shane
- Joined
- Jun 10, 2009
- Messages
- 6,518
- Reaction score
- 6,374
Well... I said screw it and decided to put three pickups in my latest experimental build..
And.. I'll admit.. this was in part becasue some dumbass forgot to drill the pickup connector hole before setting the neck...... It was going to be a junior style with two pickups to test out some new templates..... so i was thinking Jr. and totally bogarted the hole..
ANYWAY... through a Face book banter session.. BCR Greg suggested three pickups why not!!
THEN. .. I decided.. If im gonna do that... I might as well be really stupid and add a a superswitch to it for coil splitting....
THEN I thought... I didnt put any internal routing in it for a selector switch in the standard LP position... wait... why not use a Tele control plate and put the swithc on that, then modify my Jr pickguard for this configuration???
Sooooooooo I also said screw the wraparound bridge....
What we are gonna end up with is:
1 3/4" thick single cut body 1" of walnut 3/4" flamed maple top
Mahogany neck, 24.75" scale. 14" radius, bound Ebony Board, Mini trap inlays, SS frets
Nicklel Hardware: Tonepros Kulson Tuners, Tone Pros locking Bridge, Stop tail with TonPros Steel locking studs.
Nickel Tele control plate with Push Pull volume pot
Pups will be B) Duncan Alternative 8 M) Duncan Custom 5 and N) Duncan Jazz
Pickp selection with the switch will be:
Bridge Full
Brige / Mid split
Mid full
mid / neck split
Neck full
Engaging the push pull volume will kill the mid pup giving single coil bridge and neck in positions 2 and 4
Here we go!!!!
Bridge Full
Brige / Mid split
Mid full
mid / neck split
Neck full
Here we go!!!!
