80smetalhead
- Joined
- Jul 19, 2010
- Messages
- 46
- Reaction score
- 85
New Schaller’s kick ass. As close to rock solid security as possible.
Every guitar gets its own strap.Every guitar doesn't get $150 strap though...
Just a note- you can’t reuse the existing Gibson installed screws on Schallers made within the last couple years. The new assembly has the strap button and screw as one piece. The new screw is fairly thick, too. I bought some and ended up not wanting to use them on the LP I bought them for. Creeped me out, screwing that thick screw into the smaller screw hole.
I use the same rubber washers from Fender and they seem very tight to me. So yeah, maybe a slightly biggere button would be good. The other thing that I’ve recently switched to is the Levi’s Hemp straps woth Cork ends. The Cork doesn’t seem to get stretched out like leather ends do. So everything fits tight.![]()
this is what my failed setup looks like - I think a larger button there will do the trick?
Had a pretty close call with my 50s LP where the strap fell off the button even though it was held in place by a rubber strap lock. Luckily, I was able to catch it mid-drop and it never touched the ground. With that being said, these buttons look tiny compared to others and upgrading that is top priority.
Whats the proper/correct buttons to get? Being era correct would be nice but not at the expense of security. A drop-in replacement would be preferred to prevent modification.
Does such a thing exist?
That’s what toothpicks and wood glue are for.Just a note- you can’t reuse the existing Gibson installed screws on Schallers made within the last couple years. The new assembly has the strap button and screw as one piece. The new screw is fairly thick, too. I bought some and ended up not wanting to use them on the LP I bought them for. Creeped me out, screwing that thick screw into the smaller screw hole.
I tried those about 10-15 years back when they were round disks. I loved the idea, but at the time the build quality or design wasn’t up to snuff.For me the better is D’Addario planet waves, no modification needed, and have a cable retainer...
Finally, the cheapest solution
Either get shaller or Dunlop strap locks, you’ll need to replace the buttons but they work greatHad a pretty close call with my 50s LP where the strap fell off the button even though it was held in place by a rubber strap lock. Luckily, I was able to catch it mid-drop and it never touched the ground. With that being said, these buttons look tiny compared to others and upgrading that is top priority.
<snip> Ended up getting rid of them because (superficial comment upcoming...) I just couldn't stand the way they looked. Like curb feelers on a Ferrari. <snip>
