I’m considering changing out the pickups and PCB harness out of my 2020 Classic
When buying a prewired harness should I get short or long pots for this model ?
Long shaft for all USA line Gibson Les Pauls. I do believe the Historics use short shaft (though you can still use long shaft with an extra nut inside to shorten them).
Ordered a set of SD CS Angus Young pickups and a whole new wiring harness is going in with them
Will take a few weeks by the time they arrive and I get them installed
Very nice, thank you for sharing your wiring harness information. I’m guessing the plate drops onto the floor of the control cavity and then soldering in the pups, Jack, and switch. It looks like you’ve got very nice electronics for your Lp.
I’ve only recently become aware of the effect of a treble bleed circuit, having spent most of the past 40 years playing acoustics. I guess I’m wondering why treble bleed isn’t standard. Yes, extra parts increase the cost, but it seems that the benefits would be worth the relatively nominal cost.
